Xin File Phá Khóa Sony SO-01e
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi longapple.net, 25/2/16.
  1. 25/2/16 lúc 14:17
    longapple.net
    longapple.net
    Nhận cây sony mật khẩu khóa máy mà không tìm thấy file của con này . a nào có file phá khóa của con này or file chuẩn chạy con này cho e xin với . dh
  2. 25/2/16 lúc 14:20
    nokia112
    nokia112
    , Format Code
    Sony Xperia AX SO-01E Hard Reset. All reset methods are available here. You can easily hard reset your android mobile for free. Please note, all data will be erased after hard reset. Please try all methods one by one until reset your mobile phone.
    Search Keywords :
    Sony Xperia AX SO-01E hard reset code. Sony Xperia AX SO-01E hard reset. Sony Xperia AX SO-01E hard reset gsm forum. Sony Xperia AX SO-01E hard reset code. Sony Xperia AX SO-01E hard reset button. Sony Xperia AX SO-01E format key. Sony Xperia AX SO-01E format code. how to format Sony Xperia AX SO-01E. Reset software and secret keys.
    Sony Xperia AX SO-01E Hard Reset format code solution
    Important Info : Must read below post before hard reset your mobile.
    >>>>> Things To Consider Before Hard Reset Your Mobile
    SONY XPERIA AX SO-01E HARD RESET :
    First method:
    Power off/ Switch off your mobile.
    After that press and hold Volume Up + Volume Down + Power button until you see menu.
    Next, choose option Recovery from menu using Volume Down to navigate, and Volume Up.
    Note : If Volume Up button doesn’t work, then use Power button to select.
    Now you will see yellow triangle and Android mobile logo.
    Then press Volume Down + Volume Up to see menu.
    Please use Volume buttons to select option “wipe data / factory reset”, and confirm that using Power button.
    nhanh gọn lẹ
  3. 25/2/16 lúc 14:32
    CuDuy-VF
    Super Moderator
    CuDuy-VF
  4. 25/2/16 lúc 14:39
    longapple.net
    longapple.net
  5. 25/2/16 lúc 14:44
    ditim
    ditim
    lấy tools sony pc ra tự tải tự update văng hết mã khóa lock ngay
  6. 25/2/16 lúc 15:27
    Mr Kuty
    Mr Kuty
    cái nào nhanh gọn thì làm, mình thì tán file remove lock :-*
  7. 11/7/16 lúc 08:24
    hoangthanhpro
    hoangthanhpro
