Smartisan U2 Pro Remove Password - FRP By MRT
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi thanhnamPDAviet, 26/2/18.
Trạng thái chủ đề:
Không mở trả lời sau này.
  1. 26/2/18 lúc 08:35
    thanhnamPDAviet
    thanhnamPDAviet
    Mã:
    @thanhnamPDAviet
    >>>Try connect to mobile...Success
    	CPU_SN:  0xC5A95467
    	MSM_ID:  0x000460E1
    >>>init mobile...Success
    >>>Downloading boot...Success
    >>>Switch mobile to RE\WR ...Success
    	Flasy type:  eMMC
    >>>>ƠưÔÚ¶ÁÈ¡ÊÖ»ú·ÖÇøÊư¾Ư...Success
    	Clear Moblile Lock data...
    	After Click Mobile userdata will be lost...
    	Format add: ADD:0x0124000000   Size:0x0D6B7FBE00
    	Erase Userdata.. Success
    	Erase Userdata Block 2...
    	Erase Userdata Block 3...
    	Erase Userdata Block 4...
    >>>all is done
    	Please disconnect mobile set,and hold vol up and power key
    	Mobile will be into recovery
    	Click Restart
    	if mobile hand on logo or auto restart...
    	You can in recovery erase data
    	After ease data in recovery mobile will working normal
Trạng thái chủ đề:
