Samsung Galaxy Note Edge SM-N915T Unlock Ok !
Thảo luận trong 'SAMSUNG ANDROID' bắt đầu bởi taki7610, 9/7/15.
  1. 9/7/15 lúc 11:51
    taki7610
    taki7610
    Mã:
    To connect SM-N915T phone you have to perform the following steps:
    1. Disconnect USB cable from phone.
    2. Go to Menu->Settings->More->About Device.
    3.Tap on "Build number" 7 times to enable developer options.
    4. Go to Menu->Settings->More->Developer options.
    5. Turn on "USB Debugging" option.
    6. Go to dial window.
    7. Enter "*#0808#" number.
    8. Select "DM+Modem+ADB".
    9. Press Home button.
    10. Restart phone.
    11. Press "Read Info" in software.
    Platform: Samsung Android
    Selected port: COM10
    Selected model: SM-N915T
    Selected file: C:\Users\Dell_64\Downloads\Cert-SM-N915T-355024060231017.cert
    ADB server killed.
    Please, press "OK" button on the phone to allow USB debugging..
    Detected phone model: SM-N915T
    Firmware compiled date: Thu Nov 20 21:03:25 KST 2014
    PDA version: N915TUVU1ANK3
    CSC version: N915TTMB1ANK3
    SW version: N915TUVU1ANK3
    Phone IMEI: Unknown
    Phone SN: R38G109TXMY
    Android version: 4.4.4 (KTU84P)
    Checking Root:
    Phone is Rooted.
    Checking Certificate file...
    Certificate file successfully checked
    Writing Certificate...
    Phone connected successfully
    Writing new phone IMEI...
    Checking certificate compatibility...
    Certificate is compatible
    Phone will restart now. Please don't disconnect cable!
    Certificate has been written successfully
    Please, restart the phone to apply changes
