Pro Việt Hóa cần giúp
Thảo luận trong 'VIỆT HÓA ANDROID' bắt đầu bởi Hoàng Gia Hải, 21/7/15.
  1. 21/7/15 lúc 07:56
    Hoàng Gia Hải
    Hoàng Gia Hải
    Pro giúp e lỗi này với ạ
    C:\apktool\apktool>cmd.exe
    Microsoft Windows XP [Version 5.1.2600]
    (C) Copyright 1985-2001 Microsoft Corp.
    C:\apktool\apktool>apktool b C:\apktool\apktool\Mms
    I: Using Apktool 2.0.0
    I: Checking whether sources has changed...
    I: Checking whether resources has changed...
    I: Building resources...
    warning: string 'ipmsg_send_exception' has no default translation.
    warning: string 'notification_multiple' has no default translation.
    C:\apktool\apktool\Mms\res\layout\wallpaper_item_each.xml:6: error: No resource
    identifier found for attribute 'smartFit' in package 'com.mediatek'
    Exception in thread "main" brut.androlib.AndrolibException: brut.androlib.Androl
    ibException: brut.common.BrutException: could not exec command: [C:\DOCUME~1\Adm
    in\LOCALS~1\Temp\brut_util_Jar_6998391556681238863.tmp, p, --forced-package-id,
    127, --min-sdk-version, 19, --target-sdk-version, 19, --version-code, 19, --vers
    ion-name, 4.4.2, -F, C:\DOCUME~1\Admin\LOCALS~1\Temp\APKTOOL2956946718678418703.
    tmp, -0, arsc, -I, C:\Documents and Settings\Admin\apktool\framework\1.apk, -I,
    C:\Documents and Settings\Admin\apktool\framework\2.apk, -S, C:\apktool\apktool\
    Mms\res, -M, C:\apktool\apktool\Mms\AndroidManifest.xml]
    at brut.androlib.Androlib.buildResourcesFull(Androlib.java:458)
    at brut.androlib.Androlib.buildResources(Androlib.java:396)
    at brut.androlib.Androlib.build(Androlib.java:285)
    at brut.androlib.Androlib.build(Androlib.java:256)
    at brut.apktool.Main.cmdBuild(Main.java:225)
    at brut.apktool.Main.main(Main.java:84)
    Caused by: brut.androlib.AndrolibException: brut.common.BrutException: could not
    exec command: [C:\DOCUME~1\Admin\LOCALS~1\Temp\brut_util_Jar_699839155668123886
    3.tmp, p, --forced-package-id, 127, --min-sdk-version, 19, --target-sdk-version,
    19, --version-code, 19, --version-name, 4.4.2, -F, C:\DOCUME~1\Admin\LOCALS~1\T
    emp\APKTOOL2956946718678418703.tmp, -0, arsc, -I, C:\Documents and Settings\Admi
    n\apktool\framework\1.apk, -I, C:\Documents and Settings\Admin\apktool\framework
    \2.apk, -S, C:\apktool\apktool\Mms\res, -M, C:\apktool\apktool\Mms\AndroidManife
    st.xml]
    at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.jav
    a:419)
    at brut.androlib.Androlib.buildResourcesFull(Androlib.java:444)
    ... 5 more
    Caused by: brut.common.BrutException: could not exec command: [C:\DOCUME~1\Admin
    \LOCALS~1\Temp\brut_util_Jar_6998391556681238863.tmp, p, --forced-package-id, 12
    7, --min-sdk-version, 19, --target-sdk-version, 19, --version-code, 19, --versio
    n-name, 4.4.2, -F, C:\DOCUME~1\Admin\LOCALS~1\Temp\APKTOOL2956946718678418703.tm
    p, -0, arsc, -I, C:\Documents and Settings\Admin\apktool\framework\1.apk, -I, C:
    \Documents and Settings\Admin\apktool\framework\2.apk, -S, C:\apktool\apktool\Mm
    at brut.util.OS.exec(OS.java:89)
    a:413)
    ... 6 more
    C:\apktool\apktool>
  2. 21/7/15 lúc 08:14
    Anh Tuấn™
    Anh Tuấn™
    update java mới nhất apptool cũng update lên luôn đi
    chỗ này báo không có từ điển nè
    mấy prro vào giúp tiếp bạn ý nè
  3. 21/7/15 lúc 08:21
    Hoàng Gia Hải
    Hoàng Gia Hải
    pro giúp e cái dòng này thôi ạ
    C:\apktool\apktool\Mms\res\layout\wallpaper_item_e ach.xml:6: error: No resource
  4. 21/7/15 lúc 08:36
    Hoàng Gia Hải
    Hoàng Gia Hải
    ko ai giúp hết :cry:
  5. 21/7/15 lúc 08:44
    QuocToanGSM
    V.I.P
    QuocToanGSM
    Bạn úp Hết File framework và file bạn Build lỗi lên đây nhé mình cố gắng giúp xem
  6. 21/7/15 lúc 09:05
    Hoàng Gia Hải
    Hoàng Gia Hải
  7. 21/7/15 lúc 09:13
    QuocToanGSM
    V.I.P
    QuocToanGSM
  8. 21/7/15 lúc 09:16
    Hoàng Gia Hải
    Hoàng Gia Hải
    đúng rồi mod ............
  9. 21/7/15 lúc 09:17
    QuocToanGSM
    V.I.P
    QuocToanGSM
    ver 4.4.2 hả bạn, Bạn đã úp hết FRamework chưa thấy có 1 cái , Model máy là gì bạn
  10. 21/7/15 lúc 09:17
    Hoàng Gia Hải
    Hoàng Gia Hải
    e dang VH cái Asus China Too1 4.4.2 nếu có file cho e xin lun y mod
  11. 21/7/15 lúc 09:18
    luat_gsm
    luat_gsm
    Cái Mms.apk bị lỗi bạn quăng cái SecSettings.apk lên làm gì :D
  12. 21/7/15 lúc 09:23
    Hoàng Gia Hải
    Hoàng Gia Hải
    giúp e 2 apk đó thôi còn lại done hết rồi
  13. 21/7/15 lúc 09:25
    luat_gsm
    luat_gsm
    File build ok, Nếu lỗi bạn load apktool mới nhất về nhé
  14. 21/7/15 lúc 09:26
    Điệp Liên Tú
    Điệp Liên Tú
    Tìm theo đường dẫn và xoá bỏ dòng số 6 là đc.
  15. 21/7/15 lúc 09:27
    Hoàng Gia Hải
    Hoàng Gia Hải
  16. 21/7/15 lúc 09:28
    Hoàng Gia Hải
    Hoàng Gia Hải
    sr mọi người úp nhầm apk
    giúp e 2 link apk mới úp
    Chỉnh sửa cuối: 21/7/15
  17. 21/7/15 lúc 09:44
    QuocToanGSM
    V.I.P
    QuocToanGSM
    chính xác là lỗi này
  18. 21/7/15 lúc 09:47
    QuocToanGSM
    V.I.P
    QuocToanGSM
    chờ mình build luôn cho bạn
  19. 21/7/15 lúc 09:48
    luat_gsm
    luat_gsm
    Giờ bạn làm theo mình nhé:
    1. Mms.apk bạn theo đường dẫn Mms\res\layout\ mở file mở file wallpaper_item_each.xml xóa dòng số 6 rồi build lại
    2. SystemUI .apk theo đường dẫn SystemUI\res\values mở file styles.xml xóa dòng 69 rồi build lại
    vậy là done :D
  20. 21/7/15 lúc 09:55
    luat_gsm
    luat_gsm
    Log đây................ :eek:
  21. 21/7/15 lúc 09:58
    Hoàng Gia Hải
    Hoàng Gia Hải
    thank bạn mình cũng làm như zậy thử rồi done nhưng chép vào có lỗi fì ko zậy
  22. 21/7/15 lúc 10:00
    luat_gsm
    luat_gsm
    Build ok thì chép vào thui, nếu có lỗi mất icon or FC.... thì tính tiếp :D
  23. 21/7/15 lúc 10:05
    Hoàng Gia Hải
    Hoàng Gia Hải
    6 cái asus china úp tv mà lấy apk vh từ hơm wa tới giờ còn kẹt 2 apk kia thôi
  24. 21/7/15 lúc 10:07
    Hoàng Gia Hải
    Hoàng Gia Hải
    Thank mod trc nha ...........
  25. 21/7/15 lúc 10:16
    QuocToanGSM
    V.I.P
    QuocToanGSM
  26. 21/7/15 lúc 10:20
    Hoàng Gia Hải
    Hoàng Gia Hải
  27. 21/7/15 lúc 10:25
    QuocToanGSM
    V.I.P
    QuocToanGSM
    ok chưa anh :-* ....
  28. 21/7/15 lúc 10:51
    Hoàng Gia Hải
    Hoàng Gia Hải
  29. 21/7/15 lúc 10:55
    QuocToanGSM
    V.I.P
    QuocToanGSM
  30. 21/7/15 lúc 11:37
    Hoàng Gia Hải
    Hoàng Gia Hải
    có tool chép apk chuẩn ko mod cho e xin lun
  31. 21/7/15 lúc 12:04
    Hoàng Gia Hải
    Hoàng Gia Hải
    test ok thank moi người nhìu đễ chiều e làm xong 6 cái e chia sẽ file cho ae đỡ mắc công
