Bán PP-50, PP-50BD, PP-100, PP-100N, PP-100AP, and PP-100II Adjustment Program
Thảo luận trong 'LAPTOP, MACBOOK, MÁY TÍNH BÀN VÀ PHỤ KIỆN.' bắt đầu bởi phuongdong203, 1/11/25 lúc 08:16.
    phuongdong203 (Offline)
    111,111 (VNĐ)
    Ship COD
    0936161390 Click để xem
    369 trường chinh - ngay ngã tư sở. (Click để xem bản đồ)
    Gửi 1/11/25 lúc 08:16, 0 Trả lời, 20 Đọc
  1. 1/11/25 lúc 08:16
    phuongdong203
    phuongdong203
    The Epson Adjustment Program (sometimes called a “Service Program Epson PP-50, PP-50BD, PP-100, PP-100N, PP-100AP, PP-100II”) is an official Epson service software used by technicians to perform printer maintenance, calibration, and system resets.
    For the PP-50, PP-50BD, PP-100, PP-100N, PP-100AP, and PP-100II, this tool provides full support for all models in the Discproducer family.
    These printers combine high-quality inkjet printing with robotic disc handling. Over time, usage causes waste ink counter overflow, misalignment, and performance drift — all of which the Adjustment Program can fix.
    Supported Models
    The program supports the following Epson Discproducer models:
    • Epson PP-50 – CD/DVD publishing printer
    • Epson PP-50BD – Blu-ray Disc publisher version
    • Epson PP-100 – Standard Discproducer model
    • Epson PP-100N – Network model for shared production
    • Epson PP-100AP – Autoprinter version (no recorder drives)
    • Epson PP-100II – Next-generation high-speed model
    Each version of the Adjustment Program detects the model automatically and loads the correct maintenance and calibration parameters.
    Main Features of the Adjustment Program
    1. Waste Ink Counter Reset
    • Clears the “Service Required” or “Ink Pad End of Service Life” error.
    • Restores printer operation after the waste ink absorber reaches its limit.
    • Prevents unnecessary downtime or costly service visits.
    2. Ink System Maintenance
    • Enables ink charge, ink flush, or head cleaning functions.
    • Resets ink level monitoring data.
    • Ensures even ink flow and prevents printhead clogging.
    3. Printhead Alignment and Calibration
    • Performs automatic and manual bi-directional alignment.
    • Adjusts printhead position, carriage motor, and sensor offsets.
    • Optimizes printing accuracy for CD/DVD surfaces.
    4. EEPROM Initialization
    • Resets internal memory (EEPROM) data to factory defaults.
    • Useful when replacing logic boards or restoring malfunctioning units.
    5. Maintenance Report & Error Log
    • Displays internal counters and error logs.
    • Helps diagnose component wear and operational errors.
    6. Drive and Robotic Arm Test (for Discproducer series)
    • Tests the robotic disc picker arm and tray mechanism.
    • Checks movement precision and calibration of optical sensors.
    7. Firmware Information & System ID
    • Shows printer firmware version, system ID, and region code.
    • Essential for technicians performing firmware upgrades or replacements.
    System Requirements
    • Operating System: Windows XP / 7 / 8 / 10 / 11 (32-bit or 64-bit)
    • Interface: USB 2.0 or Network (for PP-100N)
    • RAM: 1 GB minimum
    • Disk Space: 100 MB free
    • Administrator rights are required to run the program.
    How the Adjustment Program Works
    1. Connect your printer via USB or LAN.
    2. Run the Adjustment Program for your model.
    3. Select the “Particular Adjustment Mode.”
    4. Choose the desired function — e.g., Waste Ink Counter Reset, Head Cleaning, EEPROM Initialization.
    5. Execute the operation and follow on-screen instructions.
    6. Power cycle the printer after completion.
    This simple process can restore printer operation within minutes, avoiding downtime and service costs.
    Benefits of Using the Epson PP-Series Adjustment Program
    • Extend printer life by maintaining calibration and clearing waste ink warnings.
    • Reduce service costs by performing in-house maintenance.
    • Increase productivity in CD/DVD production lines.
    • Ensure consistent print quality across large disc batches.
    • Ideal for service technicians and production operators.
    Common Use Cases
    • After ink pad overflow warning (“Service required” message).
    • When replacing printhead or mainboard.
    • To calibrate robotic disc handling arms.
    • For quality assurance and preventive maintenance schedules.
    Important Notes
    • Always use the correct version for your printer model.
    • Backup your settings before running EEPROM or initialization functions.
    • This program is designed for service engineers and professionals.
    • Misuse may lead to configuration loss or damage.
    Conclusion
    The Epson PP-50, PP-50BD, PP-100, PP-100N, PP-100AP, and PP-100II Adjustment Program is an essential maintenance utility for Epson Discproducer systems. It empowers users to reset, calibrate, and maintain their CD/DVD/Blu-ray production printers efficiently. Whether for professional print studios, duplicator service centers, or internal company production lines, this software ensures reliability, performance, and cost-effective printer management.
    Whatsapp : https://wa.me/84936161390
    Website : www.datvietcomputer.com/
    Facebook : https://m.me/datvietcompputer
    Telegram https://t.me/datvietcomputer
    Zalo : https://zalo.me/84936161390
