Huawei Y3 LUA-L02 Unlock Network By NCK
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi thanhnamPDAviet, 3/3/18.
Trạng thái chủ đề:
Không mở trả lời sau này.
  1. 3/3/18 lúc 08:59
    thanhnamPDAviet
    thanhnamPDAviet
    3 máy 1 lượt.hihi
    Mã:
     @thanhnamPDAviet
    Selected connection metod: FLASH Mode
     Exe version: NCKDongle AndroidMTK 2.5.8.5
     Selected model: Ascend Y3 II[LUA-L02]
     Action: Unlock
     Reinsert phone battery.
     Battery must be charged.
     Phone must be off with battery inside.
     Please insert USB cable now...
     Detected : MediaTek PreLoader USB VCOM (Android) (COM15)
     Boot mode: Preloader
     Phone detected...Please wait
     Sending DA agent, please wait...
     Using Algo 2.
     BaseBand CPU :MT6735M
     BaseBand CPU Secure Version : FF
     BaseBand CPU Bootloader Version : 01
     INT RAM: 128 KB SDRAM
     EXT RAM: 1 GB  DRAM
     EMMC: (58Gb+8192Mb) SAMSUNG 0x464e31324d42
     EMMC FW VERSION: 06:00:00:00:00:00:00:00
     EMMC CID: 150100464E3132 : 000000000000000000
     EMMC UA SIZE: 0x1d2000000
     BOOT STYLE: EMMC BOOT
     FULL LENGTH: 0x1d2880000	  [7.290 GB]
     Preloader SEC version: 2
     Status: USB_HIGH_SPEED
     IMEI[1]: 86982102034
     IMEI[2]: 86982102034
     Reading security, wait...
     SIM[1]:
     Block1(N): Locked (remain:10) Code : 86474623
     Block2(NS): Unlocked
     Block3(SP): Unlocked
     Block4(C): Unlocked
     SIM[2]:
     Block1(N): Unlocked (remain:10) Code : 12345678
     Block4(C): Unlocked
     Please note, some firmwares can display wrong codes.
     Some firmwares can be hardlocked.
     If this happen, perform direct unlock.
     If direct unlock fail,use reset package from support.
     If reset package not exist in support,request help in forum.
     Wait untill phone will start charging.
     All done.
     Action: Unlock
     Using Algo 2.
     EXT RAM: 1 GB  DRAM
     SIM[1]:
     Block1(N): Locked (remain:10) Code : 80892296
     Block4(C): Unlocked
     SIM[2]:
     Block4(C): Unlocked
     All done.
     Action: Unlock
     Using Algo 2.
     EXT RAM: 1 GB  DRAM
     SIM[1]:
     Block1(N): Locked (remain:10) Code : 90198199
     Block4(C): Unlocked
     SIM[2]:
     Block4(C): Unlocked
     All done.
Trạng thái chủ đề:
