Mua Franck Muller Vanguard Navy
Thảo luận trong 'ĐIỆN TỬ - ĐIỆN LẠNH - ĐIỆN GIA DỤNG.' bắt đầu bởi anyick, 6/5/25.
    anyick (Offline)
    Cần Thơ
    270,000 (VNĐ)
    Chuyển Phát Nhanh
    23659874 Click để xem
    Gửi 6/5/25, 0 Trả lời, 101 Đọc
  1. 6/5/25 lúc 14:50
    anyick
    anyick
    If you like the Franck Muller Vanguard Yachting luxury cheap Watches , but don’t like the compass went up by in the center of the dial, prepared to in luck-because the 2025 Franck Muller Vanguard Navy is essentially the same as the Yachting watch, except without any center structure (and the crown safeguard is also made of steel, definitely not colored like the Yachting watch). Before Richard Mille evolved into the top luxury watch brand, Franck Muller was the ruler of tonneau cases, along with the Vanguard represents its sportiest tonneau case.
    Available in three uncontroversial watch dial colors: silver (which appearance white), blue, or black (which is more dark gray). If you don’t understand what separates the Vanguard Navy from regular Vanguard model, it is very basically the crown guard. Often the “regular” Vanguard model doesn't have crown guard at all, whilst the “racing” Vanguard model possesses a chunky crown guard. Jacob & Co replica Watches
    2025 Franck Muller Vanguard Navy watch specifications
    Unit name Vanguard Navy
    V 41 YT SC DT NAVY STG NR BR (AC) (black)
    V 41 YT SC DT NAVY STG BL BR (AC) (blue)
    V 41 YT SC DT NAVY BC BR (AC) (silver)
    Event material Stainless steel
    Scenario width Width: 44 mm
    Thickness: 12. 6 mm
    Between lugs: 53. 7 mm
    Case shape Tonneau
    Crystal Sapphire
    Watch dial functions Hand-applied numerals (rose gold outline on black color model, black outline with silver model)
    Water proofing 30 minutes
    Caliber FM 800-DT (automatic, 8 defeats per second)
    Reserve of power 42 hours
    Performs Hours, minutes, seconds, night out at 6 o'clock
    Strap material Rubber tie with folding clasp
    replica Zenith Chronomaster Sport
    replica Audemars Piguet Watches
    replica Franck Muller Watches
    luxury Replica watches
