Chia Sẻ : ROM GỐC VIỆT HÓA 4.1.2 [ SKY-A810 S/K ]
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi thangquyen, 15/6/14.
  1. 15/6/14 lúc 08:20
    thangquyen
    thangquyen
    THÔNG TIN PHIÊN BẢN ROM VIỆT HÓA FIX LỖI VERSION 1.0 LTE M
    - FIX LỖI TIN NHẮN 160 KÍ TỰ VÀ NHẮN TIN TỔNG ĐÀI.
    - FIX LỖI HIỂN THỊ TÊN GỌI ĐẾN LƯU +84 TRONG DANH BẠ
    - ADD THÊM FLASH TRÊN 4.1.2
    - THAY BỘ GÕ MẶC ĐỊNH THÀNH LABAN KEY
    - FIX GPS , FIX TÌM KIẾM BẰNG GIỌNG NÓI
    - EDIT GIAO DIỆN THEO CHUẨN 4.1.2 CỦA PANTECH
    - ADD THÊM ỨNG DỤNG CHIA SẺ FILE SIÊU NHANH QUA WIFI
    - ADD THÊM ỨNG DỤNG BẬT TẮT ĐÈN 3 PHÍM CẢM ỨNG TIẾT KIỆM PIN
    - SỬ DỤNG CAMERA APP CỦA 870 CHỤP ẢNH VÔ ĐỐI
    - SMS ĐẾN SÁNG MÀN HÌNH VÀ HIỂN THỊ DẠNG POP UP
    - KHÓA MÀN HÌNH BẰNG CẢM ỨNG "CHẠM VÀO ĐỒNG HỒ TRÊN STATUS"
    - VÀ RẤT NHIỀU CẢI TIẾN KHÁC NỮA ... ANH EM HÃY CHỜ ĐỢI VÀ TRẢI NGHIỆM NHÉ.
    HƯỚNG DẪN UP ROM VÀ CHÚ Ý QUAN TRỌNG :
    [ MÌNH SẼ KHÔNG CHỊU TRÁCH NHIỆM VỚI BẤT CỨ TRƯỜNG HỢP NÀO KHÔNG LÀM THEO ĐÚNG HƯỚNG DẪN Ở TOPIC NÀY . NẾU LÀM SAI CÓ THỂ DẪN ĐẾN MÁY BẠN BỊ BRICK VĨNH VIỄN ]
    BƯỚC 1 : KHÔNG CẦN BIẾT CÁC BẠN ĐANG Ở BẢN ROM NÀO . YÊU CẦU CẦN CÀI ĐẶT LẠI ROM GỐC 4.0 CỦA
    LINK DOWNLOAD ROM GỐC BINX 4.0.4 CÓ THỂ DOWNLOAD TẠI ĐÂY :
    810S : http://dmfile.curitel.com/self_binary/sky_binary/real/IM-A810S/IM-A810S_S0213225.BINX
    810k : http://dmfile.curitel.com/self_binary/sky_binary/real/IM-A810k/IM-A810K_S0835214.BINX
    BƯỚC 2 : SAU KHI ĐÃ CÀI ĐẶT ROM GỐC 4.0.4 OFFLINE THÀNH CÔNG . CÁC BẠN DOWNLOAD TIẾP ROM GỐC
    BINX 4.1.2 TẠI ĐÂY . CHÚ Ý ĐÂY LÀ BƯỚC CỰC KÌ QUAN TRỌNG. NẾU MÁY BỊ BRICK THÌ NGUYÊN NHÂN LÀ Ở BƯỚC NÀY . VẬY NÊN MÌNH HI VỌNG ANH EM NÊN CÂN NHẮC TRƯỚC KHI LÀM HOẶC YÊN VỊ Ở 4.0.4
    LINK DOWNLOAD BINX 4.1.2 :
    810S : http://dmfile.curitel.com/self_binary/sky_binary/real/IM-A810S/IM-A810S_S0213308.BINX
    810K : http://dmfile.curitel.com/self_binary/sky_binary/real/IM-A810K/IM-A810K_S0835323.BINX
    BƯỚC 3 : SAU KHI CÀI ĐẶT ROM GỐC BINX OFFLINE 4.1.2 THÀNH CÔNG .
    Ẩn nội dung
    BƯỚC TIẾP THEO CHÚNG TA PHẢI LÀM LÀ CÀI ĐẶT ROM VIỆT HÓA NỮA THÔI . MÌNH CÓ VÀI CHÚ Ý NHỎ SAU ĐÂY :
    - VÌ CWM DÀNH CHO 810 4.1.2 CHƯA ĐỌC ĐƯỢC THẺ NHỚ. NÊN KHI DOWNLOAD ROM VIỆT HÓA CÁC BẠN GẮN CÁP VÀ COPY ROM VÀO BỘ NHỚ TRONG ĐỂ CÀI ĐẶT.
    -CHÚ Ý QUAN TRỌNG CÁC BẠN KHÔNG ĐƯỢC CHẠY NHẦM CWM CỦA 4.0.4 MÀ CHỈ ĐƯỢC CHẠY CWM TỪ TOPIC NÀY.
    LINK DOWNLOAD CWM CHẠY TỪ FASTBOOT : https://www.mediafire.com/?6jpvp3yfin8uatl
    BƯỚC TIẾP THEO BẠN TẮT MÁY . BẤM TỔ HỢP 3 PHÍM MỞ NGUỒN + TĂNG VÀ GIẢM ÂM LƯỢNG ĐỂ VÀO FASTBOOT . BẠN GẮN CÁP VÀO MÁY TÍNH .
    NẾU THIẾU DRIVER FASTBOOT BẠN CÓ THỂ TẢI TẠI ĐÂY : https://www.mediafire.com/?ecbpr7nlrrc5dri
    GIẢI NÉN CWM CHẠY TỪ FASTBOOT CÁC BẠN CHẠY FILE Run_CWM_from_Fastboot.bat MÁY SẼ KHỞI ĐỘNG LẠI VÀ VÀO CWM .
    BƯỚC 4 : HƯỚNG DẪN CÀI ĐẶT ROM DẠNG ZIP TRÊN CWM :
    Ẩn nội dung
    - ở màn hình CWM mình sử dụng 2 phím tăng giảm âm lượng để lựa chọn.
    - Để up rom mới mình làm thao tác như sau :
    + đầu tiên mình chọn xuống menu : Wipe data/factory reset rồi bấm nút mở nguồn .ok
    nó chuyển sang màn hình tiếp theo . mình bấm xuống chọn Yes -- Delete all user data.
    + tiếp theo mình chọn tiếp : Wipe cache partition rồi cũng Yes ....
    + Xong rồi mình chọn tiếp advanced ---> rồi chọn Wipe davik cache ----> yes
    + tiếp theo : bạn cần format các phân vùng rom cũ trên máy . bằng cách vào menu : mouts and Storage chọn như phần trên mình làm lần lượt ở :
    + Format /cache , format /data , Format /system . FORMAT/ SYSTEM_P
    + Đến đây là xong phần chuẩn bị rồi nhé , tiếp theo chỉ việc cài đặt rom nữa thôi : bạn back ra màn hình đầu tiên sẽ thấy dòng : install zip from sdcard . bấm vào đó nhé . nó sẽ hiển thị mục lựa chọn cài đặt từ bộ nhớ máy hay thẻ nhớ ngoài nha.
    + mình chọn cài đặt từ thẻ nhớ ngoài . bộ rom mình đã download và copy sẵn trong đó rồi . mình chọn choose zip from sd card. nó sẽ dẫn đến thẻ nhớ của bạn. mình lựa chọn rom của mình là ChoimobileOS_4.1.2_810SK.zip . xong rồi mình chọn Yes -- Install ChoimobileOS_4.1.2_810SK.zip. bạn đợi nó install xong .
    - CHÚ Ý ĐỂ BẢN ROM HOẠT ĐỘNG ỔN ĐỊNH CÁC BẠN WIPE LẠI 1 LẦN NỮA
    + Bây giờ bạn bấm vô menu Reboot System Now "khởi động lại máy ngay lập tức".
    LINK DOWNLOAD VERSION 1.0 DÀNH CHO CẢ 2 PHIÊN BẢN S VÀ K :
    LINK GOOGLE : https://drive.google.com/file/d/0B3YMRj69vcSAcTFpTFliUjYwcW8/edit?usp=sharing
    LINK FSHARE :
    LINK CHOIMOBILE :
    CHECK MÃ MD5 ĐẢM BẢO FILE TẢI VỀ TOÀN VẸN :
    MD5 : 1b0611b5f0eaceb8c42335e64dfd23b1
    SHA1 : 1d52fd23128804d10cd6d5c776f7513e3bd86e4f
    BÁO LỖI VÀ HƯỚNG XỬ LÝ :
    1. CAMERA CHỤP ẢNH CÓ VẤN ĐỀ KHI LƯU ẢNH . KHÔNG TỰ CHUYỂN VỀ CHẾ ĐỘ CHỤP , ĐỨNG Ở ẢNH VỪA CHỤP . NGUYÊN NHÂN DO CAMERA 870 KHÔNG THỰC SỰ TƯƠNG THÍCH VỚI CAM CỦA 810 . HƯỚNG KHẮC PHỤC LÀ SỬ DỤNG CAMERA GỐC 810 . NHƯNG ĐỂ ĐẸP HƠN ANH EM TA DÙNG CAMERA CỦA 820. HEHE .
    DOWNLOAD FILE SAU VỀ CÀI ĐẶT QUA CWM LÀ DONE : [ TẢI VỀ ] SAU KHI CÀI ĐẶT VÀ REBOOT LẠI MÁY DÙNG ROOT EXPLORE VÀO THƯ MỤC THEO ĐƯỜNG DẪN SAU : SYSTEM_PANTECH XÓA 3 FILE SAU ĐI ĐỂ KHÔNG BỊ NHẦM LẪN GIỮ CAM CŨ VÀ MỚI " VEGACamera.apk , VEGAEyeService.apk , VEGARemoteShot.apk "
    810SK 4.1.2
  2. 15/6/14 lúc 08:40
    ThiênLong
    V.I.P
    ThiênLong
    toàn link die :p
  3. 15/6/14 lúc 08:50
    thangquyen
    thangquyen
    vẫn download bình thường nhé bạn;):p
  4. 17/6/14 lúc 16:05
    Quangmobile_ls
    Quangmobile_ls
    bạn có rom việt hóa 4.1.2 zip ko mình cần up 3 room đều treo lo go
  5. 17/6/14 lúc 16:14
    TM mobile
    TM mobile
    sao ko up BINX 4.1.2 luôn mà phải up BINX 4.0.4 rồi mới up BINX 4.1.2 hả bác?
