Asus ZenFone 3 MAX (ZC520TL (X008DB) 7.0 Remove FRP Done
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi thanhnamPDAviet, 5/6/18.
Trạng thái chủ đề:
Không mở trả lời sau này.
  1. 5/6/18 lúc 08:55
    thanhnamPDAviet
    thanhnamPDAviet
    Asus ZenFone 3 MAX (ZC520TL (X008DB) 7.0 Remove FRP By MRT
    Mã:
    @thanhnamPDAviet
    	Disconnect Mobile...
    	Re-Put the Mobile Bettery...
    	Then Connect your Phone to Computer again....
    	Please Make sure Mobile better has Power...
    >>> Searching Mobile Port...
    	Get Mobile Port is:  COM9
    >>> Device driver identification:
    	MediaTek USB Port
    >>> Mobile Has Connect...
    	CPU_NAME: MT6735
    >>> Reading Mobile Hardware Info...Success
    	HW_Inf:  8A00	SW_Inf:  CB00
    >>> Initialization Mobile ...Success
    >>> Downloading Boot1 To Mobile Phone...Success
    	The Flash Hardware Info:QE1	=====================Flash Type(eMMC)==============
    	Flash   Size: 0x00000003A3E00000 -> 14910M
    	Flash	 ID: 0x150100514531334D
    	Flash   Name: Samsung_Unknow
    	Flash symbol: QE13MB
    >>> Software Auto Switch Hight Speed Has Enable...
    >>> Swich Mobile to Hight Speed Re\Wr Port...
    	Get Mobile Port is:  COM12
    	MediaTek DA USB VCOM (Android)
    >>> Reading Mobile Map Data...Success
    >>> Extracting valid data from partition data...
    >>>>Formating Mobile USER Data...
    	ADD(HEX):0x0013C00000	Size(HEX):0x0000100000
    	Corresponding operation completed!!!
    3MB
    >>> Downloading Boot2 To Mobile Phone...
    >>> Initializationing Mobile Hardware Parameter...Success
    Mạnh Dũng VF thích bài này.
Trạng thái chủ đề:
