105 không lên nguồn
Thảo luận trong 'SỬA CHỮA PHẦN CỨNG.' bắt đầu bởi namtumobile, 1/1/15.
  1. 1/1/15 lúc 11:46
    namtumobile
    namtumobile
    máy hư manfem thay màn k lên nguồn ..bấm nguồn cosdao động ..em fals mxbox báo
    Backup saved to "C:\mobileEx\3.5\data\backup\XGOLD_RM-908_3AF6460B0F8B6067_IMEI.back"
    MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C0880291
    Using device: HTI, FW ver: 00.50, SN: 01010343
    Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
    Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514
    Module ver: 1.0.0.21762(03-12-2014), Library ver: 1.0.0.14473(03-12-2014)
    Device synchronized.
    CPU: XGOLD 110
    Using embedded SBL from MCU.
    Sending EBL Loader ...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.27
    EBL version: Default_RAM_Bootloader
    Set baud rate to: 921.60 Kbit/s
    Flash ID: 002C CB17 - 00000004 [Micron ]
    CFI information:
    Flash settings: 0/1, size: 0x00800000
    2 Block regions:
    127 x 0x00010000 = 0x007F0000
    16 x 0x00001000 = 0x00010000
    EBL ready !
    Processing file: rm908_02.700
    Downloading item CODE:hw_b1_rm908_02.700.fls, num block: 3, size: 4.20 MB
    Erasing area 0x00800000-0x00A0FFFE ...OK
    Programming completed in 35.110 s
    Erasing area 0x00C60000-0x00E8123E ...OK
    Programming completed in 35.478 s
    Erasing area 0x00FFC000-0x00FFC03E ...OK
    Programming completed in 0.138 s
    Error reading checksum!
    Total time for flashing process(boot+erase+write) was 2 min 11.222 s
    Phone type: RM-908
    SW version: V 02.70 22-02-13 RM-908 (c) Nokia
    Imei plain: 35790105473829-7
    Product code: 059R488
    Cellular system: GSM
    ASIC ID: 0x2292, type: 11
    Ppm Id: IJ
    Language Pack:
    - not available.
    Imei net: 35790105473829
    Provider: GSM Test Operator
    Counter: 0/3, 0/10
    CONFIG_DATA: 0010100000000000
    PROFILE_BITS: 0000000000040002
    BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
  2. 1/1/15 lúc 11:48
    ngoc151na
    ngoc151na
    info cái xem sao bạn..chạy full luôn chắc cố sài english quá:'''
  3. 1/1/15 lúc 11:50
    BomTấn_VFS
    BomTấn_VFS
    Info xem nó có hiện dòng LCD màu đỏ hem pác .
  4. 1/1/15 lúc 12:09
    namtumobile
    namtumobile
    Backup already exists(C:\mobileEx\3.5\data\backup\XGOLD_RM-908_3AF6460B0F8B6067_IMEI.back)
    CPU: XGOLD 110
    Sending EBL ...OK
    Boot mode: 0xCC
    CFI information:
    2 Block regions:
    EBL ready !
    Programming ...
    flashing terminated !
  5. 1/1/15 lúc 12:11
    trongnghiacoco
    trongnghiacoco
    máy còn dao động là ok rồi,xem màn hàn ok chưa ? đo tổng trở chân tiếp xúc màn xem thế nào rùi tính tiếp. mấy dòng máy này không có màn hình vẫn flash ok
